kesterdevine
I am working on a recording with a friend who has a Yamaha Motif ES. We are recording into a TASCAM FW-1082 interface to a PC running Cubase. When plugging the Motif into the interface, raising the input trim knob anywhere above 12 o'clock position creates a significant hum that increases as the trim is turned up. Without pushing the trim the signal is not hot enough. The hum is getting recorded to the track, so we can't just ignore it- we must eliminate it!
We have trouble shooted all the inputs/preamps on the FW-1082 and they work great (absolutely no noise) when using microphones and/or guitars, but the Motif is a problem.
We have tried changing cables, plugging into both the XLR, and TRS inputs, tried the HI-Z input, but the hummm remains. We have tried to eliminate anything that may be causing interference (modem,router etc..) Also, in the past I have recorded directly into a Yamaha AW16G from the Motif with no noise.
I suspect we may have a ground loop...although every outlet in the room is on the same curcuit. I don't have a lot of electrical or electronic background and could really use some advice about this.
Please if anyone has any ideas or suggestions as to how to solve this I would be very grateful.
Thanks!
Thanks!
