I had a multimix 8 usb 1.0 and thought it was pretty good. I could only send in one stereo track at a time though. I read that the firewire ones could send up to 6 or 8 tracks in at one time. I found one used for under 100$s so i bought it. It changed the way everything is set up on my comp. I used to just set the inputs to the multimix usb and the outputs to the soundcard. Now I have to set the system up to use the multimediamixer to get it to bring it in from the multimix firewire and out from the soundcard. my main problem though is that I can't get any more than channels 1 and 2 to come into the computer. If i have a mic set up in input 1 and 3 and my optios are multimix firewire 1 and firewire 2 then it won't work. I have to have it set up with inputs 1 and 2 working. And I can't even seem to get it to record the whole output as a stereo track anymore. It only record the input one and two as stereo and not the 3,4,5,6,7,8.
any suggestions?
any suggestions?
