X32 more external FX ?
  • Thread starter Thread starter FrankD77
FrankD77
FrankD77
Photographer / musician
I don't seem to able to figure this out and don't want to mess things up ;)
I'm using the x32 in a studio setting.
The DAW sends everything to busses which correlates with the channels on the x32 works great.
I'm only using 2-3 inputs for recording which i disable during mixing to get the full 32 channels for the end stage ;).
This means my x32 is almost empty in the back. Loads of in and outputs left ;)
My inserts are full with external FX gear.
The larger rack i use via the IO plugin in logic which also has benefits of course ;)
The question
Seeing the flexibility of the x32 would it be possible to dedicate for example 16 input/outputs direct to the mixbus and use them as insert on the 32 USB channels from the daw.
I already experimented with assigning an aux to a mixbus for stereo reverb which works fine splitting the controls between volume and pan. I guess 100% would mean use as insert with the x32.
But how would you route this (if possible) without losing the full inputs from the daw ?
I'm not really familiar with the deep programming of the x32. The auxes was no problem ;)
Anyone with tips ?
In short i want to be able to use more than 3 stereo effects units externally without sacrificing my 32 channels from the daw. I'm NOT using any extra cards.
Thx in advance.
