Aha!
It seems the KA6 DOES have an Achilles heel!
I have run some numbers on the phantom power delivery and it is distinctly poor.
Impressing pins 2 and 3 onto a 1.47k resistor should give me around 10mA (14.47V) for a ban on 48V supply. The KA6 open ciruit supply is however only 44.1V, bottom of acceptable tolerance but IN tolerance, so I should see around 9V.
But I don't, I get 3.6V one channel loaded that's just 2.44mA. Worse still, if I put the same load on the second channel I get a miserly 1.8V for a current of 1.23mA.
I am surprised my (2mA) P 150s worked as well as they did! (Note: the voltage/loading math does not compute because the raw internal "48"V generator is drooping but I cannot of course get at that to measure things)
Things are rather better with an 11.47 load on one channel for 26volts and therefore 2.26mA but again, loading the second channel with 11.47k causes a total droop to 13.6V i.e. just 1.19mA.
These tests were done on a rear USB 2.0 port on my new Asus build but I repeated them on my HP i3 laptop and they were substantially the same.
One point. The O/C USB volts was 5.1 but the KA6 dropped this to 4.67. However, turning spook juice on and off only changed that by 0.1V so it would seem that it is the internal 48V generator that is lacking and not the USB loading. However, I would like to try the KA6 on a "stiffer" 5V supply and so will cobble up a twin USB A to one B lead over the weekend (if anyone knows of such a beastie please tell me!)
A quick check with the Scarlet 8i6 showed it would deliver 46V off load and 11.7V into 2x the 1.47ks giving a smell under 8mA. Not quite up to specc' but pretty good. The price of course is the wall rat to lug (and lose/forget!) .
For my next trick I am going to build an XLR twin breakout box so that I can determine exactly what juice is being delivered to my AKGs and my Sontonics STC-2.
I still stand by the KA6 as the best AI in its price class, BY FAR, for latency, connectivity and sound quality. You just need to watch perhaps which cap' mikes you plug into it!
