mindbuzz
Firstly, your acoustic design is simply awesome. That along with the gear you have on your list can make an excellent control room for mixing and mastering. Obviously you want to build the least expensive decent recording system possible. But, seriously, the main thing that stands between you and a good recording is... your computer.
On a PC, the on-board soundcard is crap. We all know that. If you can afford to get a Mac, get a Mac. But if you stick with a PC, you need a better soundcard. It's a given.
I know lots of people who use Delta cards. They're not all that bad. But regarding the RME vs. Delta -- RME is far superior. Fidelity, for one. Among other things, you'll notice a huge difference between a Delta 1010 and an RME ADAT in their ability to monitor digital output. An RME card will significantly reduce your PC's latency (echo caused from converting sound A/D, analog to digital). There are other factors too, of course, not just a sound card... how much RAM you have (at the very least 512mb), how fast your CPU is (go AMD dual core if you can), what speed your hard drive is and how much space you have (at least an 80gig 7200 SATA), etc.
I think the Delta does have direct monitoring that allows you to bypass the digital signal and monitor only the analog, which will work just fine for your B1 and other mics from various external pre-amps. But if you're working with a lot of MIDI, you'll really want to reduce your CPU load as much as possible... for MIDI mastering purposes (adding VST and DirectX plugins, for example, or improving the timing of your knob turning and fader tweaks). RME's cards don't use any CPU for signal processing, so you can do more, like, add more effects, without experiencing dropout.
Hope that helps.
Hope that helps.
and maybe an external for extra storage for clients.
