R
Rod Gervais
frederic said:Do you guys actually read what I write, or should I not bother?
I never suggested he ground anything to a stake, or to a cold water pipe. I've given him sound advice based on what little we know about his environment.
I merely stated the various ways that grounded was done in the past, long before building codes. Since he's obviously not an electrician, I didn't feel it was necessary to quote pages of NEC to get my point across.
Frederic,
I wasn't addressing you specifically - however in response to this:
Originally Posted by apl - How is the electrical box grounded?
you replied:
Either to a cold water pipe (within code, but a bad idea)
which is technically incorrect - regardless of the fact that you note (and I agree) it's a bad idea - it is not within code to ground the building service panel to a cold (or any other temperature) water pipe.
You also said:
which also may or may not - be true.Two prong outlets are grounded, they just don't expose the ground for plugs.
The example I gave you of homes wired in the 50's with 2 wire romex (no ground wire) is a perfect example of this - and I really do know this to be a fact - because I live in one of those homes - and slowly rewire it as I make my way through the remodeling process.
I can tell you for a fact - there was not one gounded box or receptacle in this house when I bought the place - and the house was full of 2 prong outlets.
And yes - I did read all of your posts - as well as the original poster - and it is to him that I suggest he not even consider this himself - his best bet is to move - even having his electrician friend help him could open a can of worms with his landlord.
Sincerely,
Rod
And the electrical is only a part of it. You have misc. Drywall to patch as well, then you gotta paint.
