T
thegetch1
I'm pulling my hair out over this. I just purchased a Marshall jcm2000 amp with a 1960a lead half stack. I've been playing around with micing and recording with an sm57/at2020. No matter what I do, I am unable to get a crisp sound without this drone around 130Hz. I can't seem to EQ it out because it spans too wide and cutting too many frequencies loses the low end completely. Here is what I've tried:
Micing:
Close Micing (SM57/AT2020)
- On Cone, on axis
- 2-3 inches off cone, on axis
- 2-3 inches off cone, perpendicular to cone side
Distance Micing
- On Cone, on axis, 4-6 inches away (SM57/AT2020)
- 2-3 inches off cone, on axis, 4-6 inches away (SM57/AT2020)
- 2-3 inches off cone, 4-6 inches away perpendicular to cone side (SM57)
Guitar: (Epiphone Les Paul Standard Plus w/ Gibson 57/57+ pickups)
- Rhythm/treble/both pickup positions
- Raise/lowering pickups
Amp: (Marshall JCM2000 DSL50/1960a Lead Cab)
- Red channel low gain, higher volume
- Red channel high gain, lower volume
- EQs at noon
- EQs cutting bass to 9 o'clock
- EQs cutting bass and mids to 9 o'clock
- On/off bass boast
Preamp: (Beringer MIC100)
- In and out of recording chain, gain/output at various levels doesn't do much for the drone
Mixer: (Alesis Multimix 8 USB 2.0)
- EQ out bass to 9 o'clock (Only a 3-way EQ so whatever the bass knob cuts)
- Gain down/volume up
- Volume up/gain down
DAW (Acid Pro 7.0)
- EQ out 130ish Hz
- 60Hz hum cut filter
None of the above has worked. The only way I seem to be able to get rid of it is to cut out a swath on the EQ, but then the guitar sounds empty. It's also not a system/cable drone, because it's not there playing other instruments through the system. This only seems to happen recording distorted guitar. I definitely hear the bass droning a little from the cab, but it doesn't resonate like it does when I record it. The funny thing is that it seems to be the worst around a D# power chord (wolf tone lol?)
An example mp3 is attached
ANY ideas as to how to fix this would be greatly appreciated!
Thanks!
Getch
Micing:
- On Cone, on axis
Distance Micing
- EQs at noon
- On/off bass boast
DAW (Acid Pro 7.0)
- EQ out 130ish Hz
Thanks!
Getch
