dachay2tnr
One Hit Wonder
Intonation Whatever electric guitar I use I always hear an intonation issue when I start playing anything other than open chords including frets above the second fret.
I think that playing acoustic guitars makes your ears more sensitive to a few cents flat/sharp because the bendiness of the thinner strings don't help. As Guy says, maybe you just aren't suited or used to electric guitars?
Whats the dimension of the high E string? 10? Or thinner?
Not sure of the string dimensions. Whatever they put on at the factory - although I suspect they're 10s.
You could be right on the fact that "pulling" on the thinner strings could be part of the problem. The G string seems to be my biggest issue, and it's probably the first time I've played with an unwound G string in a gazillion years. Also, I am listening on headphones, so you can really hear everything - although I do the same thing with my Taylor when I rehearse with the band.
I played it with the group last night for the first time. They all seemed to like the PRS better, since as you noted, the Hagstrom is primarily a "jazz" guitar. I have a little more time before I decide to keep it or not. I was looking at a semi-hollow mexican telecaster, and they apparently have one in stock at the local Guitar Center. I might check it out next week.
I never thought buying something could be so difficult.
How was Dubai, btw?
