acidrock
GO PACKERS!
Wow! Hey Guy, you wouldn't happen to have a 250mb Zip drive from your VS-880 days would you? I am trying to move all my VS backups(I had about a dozen) into Sonar and then to Logic via OMF. There are still three that I need to move over (I know, I should have done this about 10 years ago...). Anyway, my Zip will not cooperate and they still go for $100 on eBay.
I am looking to retire the 880 and my old PC. So far, I have been able to migrate about a half dozen projects from Sonar to Logic. The OMF export feature works quite well. You get the audio files all lined up. Midi does not migrate, but you can import separately. Automation and effects do not migrate either, but, having the raw audio data play back in sync and in time is very cool.
Mike, I may be coming thru the Garden State in May. Will touch base.
Ha,ha,Zip drive eh?
No,I had the VS880ex,which came with a whopping 2.5 gig hard drive.If you wanted to back up you had to buy a $300 cd burner.
If you don't find what your looking for I would suggest syncing your 880 up to your computer,then go into your master block mixer and route four tracks individually through your outputs,two tracks via the master and two through the aux.In two real time passes you can get all eight tracks recorded and they will be synced up,or four times with your digital output if your worried about multiple conversions.
