Chewie
I'm using ACid Pro the record some tracks. Sometimes when I'm playing back it will sound like when you download a bad MP3. Now the drive with that stuff was compressed. When I decompressed that seemed tofixed the problem. Now when even when I record the actual recording, not just the playback, sounds like this. I recorded to another drive and no problems. The thing is when I benckmark the first drive it is getting better results.
My question is what else could be causing this noise and what I can do to find what iti s and how to fix. I also noted that CPU usage and memory usage were both low.
Running:
512Mb RAM
Dual P3 800MhZ
XP Pro SP2
Acid Pro 4
Delta1010LT
Running:
512Mb RAM
Dual P3 800MhZ
XP Pro SP2
Acid Pro 4
Delta1010LT
