Connecting studio equipment
  • Thread starter Thread starter Mr T
M
Mr T
I have a Beringher Compressor Pro. Does anyone know the best way to connect this to my Mackie mixing desk.
I bought the compressor second hand and don't have the user manual.
It has a main output then 2 channels with a +4/-10 dBu switch, send/return input, send/return Sidechain & an output. It also has 4 xlr connectors, 2 beside each channel.
Would I use Stereo leads or normal guitar leads to connect it?
If anyone could help or even direct me to any good web sites that explain how to connect different studio equipment it would be greatly appreciated.
Go to www.behringer.com and search for the manual. I know they're on there in .PDF format because I've downloaded and read them before to learn how to use my friend's. It should tell you all the basics. By the way, I'm going to guess that you'll probably want to be running them at -10dB.
I have one also. I use the main inserts. 2 TRS jacks plug into your PA L&R channel inserts then the tip goes into the IN of your Behringer and the Sleeve goes to the out of your Behringer.
