Hi,
I have a Tascam US1641 Interface and Cubase LE4.
I have setup two mono input busses. i have added two mono audio channels. I have set the Input routing for the first channel to Mono In and the input routing for my second channel to Mono In 2. I have both channels record enabled.
I am showing input on both mics (channel 1 and 2) from my tascam unit. However, I am not showing anything in Cubase for my second channel. If I make the second channel the default input bus, then channel 2 works and channel 1 doesn't. I'm not sure what it even means to make an input bus the "default", but regardless I need help. I can't figure this out and it's driving me insane.
btw - I am new to this, so you will need to speak dumbly
thanks all!
Corey
thanks all!
Corey
