V
Vigilante
Gear nut
Hi all, been a while since I had a question! Here's a simple one.
A friend of mine has a cheap-butt little snare that came with a cheap-butt little kit. The snare is some kind of cheap-butt pine or something. However, it's just for kids.
Anyhoo, the snare sounds horrible now, he wants to replace it, so for kicks, I asked if I could try to fix it instead. I first took off the batter head and tightened everything up, there was even a nut floating around in there! The internal dampener broke though, I removed it. Also the snare control hardware is busted. Oh well. The snares will have to be tightened solely by the adjusting screw, since the lever doesn't work.
My problem is the snare wires. I tightened it all up and it would sound passable if only the wires didn't buzz so much. If I put pressure on the two ends of the wires, the metal parts where the strap goes, and press down so the snares make harder contact with the head, it sounds OK. But without that pressure, it sounds like a buzzing POC.
I've now taken the snares off 3 or 4 times, I tried bending the metal to make better contact, bending the snares themselves, tweaking the whole thing a few times, to no avail. I even tried taping them down. It got a little better, but after bending things, not all the snares are perfectly lined up, so some buzz more then others, I have the same problem.
I've got two questions, then:
One, now I'm afraid if I had him buy new snares, none of them would make any better of contact. When I look at pictures of snares, the brackets at the end look the same, I can't tell if they press further down toward the head or not, I fear I'd have a similar problem of not making tight contact with the head. And note that it does not get tighter as I tighten the adjusting screw, it tightens the snares themselves, of course, but doesn't increase the pressure against the head.
Or two, should I maybe cut some of these snares off down to maybe 10 (it has 20) and then maybe the 10 will be easier to get functioning? I know some pro drummers will cut snares off for a snappier snap, I'd be willing to try it.
I have an extra Evans or Remo head around here that I can replace the batter side with, this one is generic no-name, but I'm just afraid about the buzzing snares. How can I increase the pressure against the head itself? And can I count on new snares to have better pressure in this regard?
Thanks
Thanks
