B
bsco
Member
Good day to everybody....been awhile since I have been here....hmm...(Sounds like a song title there..lol)...I have this unit which has an issue...I did have this stored for awhile and did clean it up and had it working.......I now have an issue where the SUB 2 module is not working and the track 2 VU meter doesn't show any activity....if I put in a pre-recorded recording, all 4 meters will show activity.....so I decided to swap out SUB2 with SUB1.....when I put the SUB1 module into the SUB2 position, there is no sound and no meter deflection for VU meter 2.......so I installed the SUB2 module where SUB1 goes and I get a white noise sound which is controlale with the headphone volume control.....when I put everything back init's original position, SUB 1 works great but SUB2 is dead....no sound....so....to me it would seem like I have two issues.....the first of course is that SUB2 has issues and the second is that there is also a problem with the connectors that reside in the SUB2 location on the mother board.....will have to remove the bottom cover and de-solder all the connections to the individual connectors, soak them in something that will remove any corrosion that might be in them, and then reinstall them to see of SUB1 will work there...after that I will have to work on SUB2 module.....any ideas of how to proceed with that as the module will have to be removed from the machine in order to get to probe the circuitry....I need some extender harnesses by the looks of it....any suggestions are greatly appreciated.......
