D
doulos24
OK guys I got my computer in a nice lil iso box and I decided it would be cool to remix a track I had back in the day with a new kind of semi outboard setup so here it goes.
12 tracks recorded 44.1k
001 clock set to adat 44.1k to a dm24 the dm24 has a better clock then the 001 I can hear a huge diffrence in the clocks
12 tracks outputed from a digi 001 8 analog 4 adat
to 12 inputs on dm24
process the tracks using the mixer's pan, eqs compressors etc.
mix autiomation using hui and ptle the pans go away when you send the tracks out so no pan automation just levels
output the whole mix to the 001 via spif of the dm24
alright it sounds freakin great on the dm 24 everything is jammin along then I output it back to 001 via spif and play it back. the stereo spread is freakin wide on the mix I mean really wide compared to the dm24 and if i narrow the mix it still doesn't sound the same as my dm 24 mix what gives???
I'd suggest making sure that you are wired up correctly, and that there is no processing on the PT session upon playback of the stereo file - there is no reason for PT not to be outputting the EXACT bits inputed if there is no processing.
