Bobbsy
Boring Old Git
This explains everything about digital audio...more is better, it's not complicated.
You must spread some Reputation around before giving it to miroslav again.
That link is brilliant!
I never knew that data could breath but it could explain why the mix I'm working on just now seems to need CPR.
Claytons Bobbsy - remember Claytons?
That's not really the point. People say that kind of stuff all the time, but it doesn't mean much when it comes to the actual process of recording.
People make decent recordings when they find *a comfort zone that works for them*...and that's why all the "mojo" stuff is valid IMO. If someone needs a $3k Les Paul to find his "mojo"....it's valid. Saying to him that he can play the same stuff on a $300 knock-off doesn't mean anything...because that's not HIS comfort zone.
But there's that old question that's never been answered....if a tree falls in the woods........
Recording of sound isn't just a laboratory experiment based on analytical measurments....I think we can all agree that there is a LOT of faith that goes into each recording we do.
If it was all done and provable with math, we could just plug in the correct "formula" for every session...![]()
You better be careful Jimmy. I have some REALLY bad musical theatre recordings I could post--and they are perfect earworm material.
Bwahahaha!
(There's something about theatre mixing--it's always the song you hate most that gets stuck in your head.)
So there is a good case for using more bits to work with sound once you've captured it. And if you were limited to a single bit depth throughout the entire process, from recording to mixing to mastering, then you could strongly argue that starting with the highest bit depth possible is a good idea.
Bit depth 24bit is no higher quality than 16bit. The only difference is headroom before you hit the digital distortion threshold at the 0db. Ableton for example runs everything at 32bit internally, thus you dont need to worry about ever going into the red.
Mastering Engineers want files in 24 bit so they have more headroom to play around with.
20-22,000 Hz is the extremities of the human ear (No human ear has every been able todetect higher frequencies in any test). The Nyquist law of sampling states that you need to record double that rate to get the up and down of each waveform to be able to reproduce that waveform exactly, hence 44,100 covers that range(the extra 120 was used for technical reasons). Some people record samples a litle higher than that at 48,000. Anything higher than that are prone to ultrasonic artifacts which can damage your hearing. Lookup Nyquist Shannone Law of Sampling in Google if you want the full details, and have a mathematical brain.
I think that is ENTIRELY the point! I am all for peeps being "comfortable"! But in essence if you can tell 16 bits from 24 there is something wrong with your kit!
Same for mic pres and power amps. So long as they are not overdriven, if two sound different, one or both are "wrong"!
I'd think the only way to be REALLY accurate in the experiment would be to find a way to record the same material live at the same time rather than convert a 96kHz file to 44.1kHz
Well...I never said anything about hearing differences between 16 and 24 bit...but I do hear a difference when I convert something at 96 kHz and play it back at 96 kHz... VS ...converting the exact same thing at 44.1 kHz and playing it back at 44.1 k Hz.
As I mentioned earlier...it may just be that my converters sound better at 96 than they do at 44.1...maybe it's a design thing, something in the filtering, etc....but at any rate, it's subtle, but there. So that's why I may prefer to use 96 kHz with my system.
When the 96 kHz is converted down to 44.1 for "null test" purposes...the subtle differences vanish.
No...I'm not just hearing that because I really want to hear that. Heck, I would rather hear NO difference, as then it would make choices with my converters academic.
AFA as mics and pres....I'm not sure what you are saying here...that you have to overdrive them to hear differences between them??????????
Tell you what, you can whisper into a 57 and a large diaphragm tube...and you can hear differences.
Also, I've done enough comparison tests with the various pres I have...set them all up for equal gain, "normal" levels, nothing "overdriven"...and stuck the same mic into each one, recorded each one...and it's pretty easy to hear their sonic differences....
...and none of them are "wrong".
LOL! Bring it man! I need some more crazy arcane crap in my head. I still have most of the American 80's crap stuck there. Maybe some theatre stuff will fill me up, so 'Uptown Girl' will never come back to haunt me. Aw sh*t. DAMMIT!!!!!
