Elmo89m
Im using a Marshall JCM900 that has both 16 and 8 ohm output. I dont know which to use with my cab though. It is an avatar 4x12 with only two speakers in. the cab has two input jacks and one speaker gets each jack but then there is a wire connecting the jacks together. The speakers are 8 ohm so my guess is that if i use only one of the input jacks on the cab and one on the head i will want 16 ohm and if i want to use both inputs and both outputs on the head and cab respectively i should set the head to 8 ohms. If this is right, which will sound better, the 8 ohm way or the 16? and if this is wrong then how should i do it? Thanks for the help
