Sure, here is the raw track without reverb or compression.Got you. I’d like to hear it without compression. Never found YouTube really an issue with lighter classical piano. To my ears so that’s just me, it just sounds close miked with reverb rather than ‘real’ if you know what I mean.
I tried to follow your advice in our evening session. I recorded a short piece placing a pair of DPA 4011 cardioid near the right hand side of the piano, kept the mics at the tail, and raised the audience mics up about 9ft in ORTF.The raw track sounds better but reveals a few things. The mics are too close - so you are hearing more of the hammer sounds and less soundboard. That could be why some notes jump out a bit. I think maybe you've just not found the sweet spots. I have a Yamaha grand, and with the mics close in it sounds quite similar. For noon-pop, If I must close mic, I might also put up a couple of 414's in a ordinary square room - and use something like old AKG451s doing the close mic - but if it's a classical piece of your style, the two 414s on the right hand side sound more 'real'?
I think the Mix 4 track sounds more modern - also your playing style makes it sound edited.I tried to follow your advice in our evening session. I recorded a short piece placing a pair of DPA 4011 cardioid near the right hand side of the piano, kept the mics at the tail, and raised the audience mics up about 9ft in ORTF.
In retrospect, I think this last move might have been a mistake since they sound brighter but less present than when they were wide and low.
Anyway, here is the raw track.
MIX_4
I like it better too. It seems more natural and organic.I think the Mix 4 track sounds more modern - also your playing style makes it sound edited.
Yeah, equipment, players, piano, everything is okay except the guy recording LOL.That’s a more realistic sound, but still very close and the stereo field is very strange. Are you certain you have not got two sets of mics with one around the wrong way. I’m hearing left hand right and right left which is fine if that’s where you wan5 the listener, but either the piece was glitchy or something odd happened as it’s stuttery? Some of the playing seems to feature abrupt damper mutes that damp the strings but are soundless. What kind of piano is it? The action is whisper quiet. No pedal thinks or too quick pedal offs. If you are using DPA mics be very careful with placement
What is the room like? I hear absolutely no room sound, so these audience mics? What are they contributing? I think maybe whatever you are doing is too clinical. Not enough musical. What does a simple stereo recording sound like? No closer than say 2m/6ft? A pair of cardioids maybe in X/Y? You seem to have players, pianos and mics galore, but they’re not quite gelling together, more like fighting a bit?
I had no chance to record this weekend, but I uploaded the single microphone tracks I used in MIX_4 so that, if you got time, you can listen to them and tell me which one would be the best starting point and how to proceed from there.A concert hall? You haven’t given us a clue in the recordings. I was thinking a large practice room, with sound treatment, that kind of thing. If it is a typical one then the job is to capture the instrument in the space. A nice piano in a concert hall should sound like the ‘whole thing’. I would suggest, as you have a decent mic collection, using just two mics to start with. Forget clever techniques and do a simple X/Y no close than 2m, perhaps further, or even an A/B pair and experiment with simpler stuff. At some point you will capture the right kind of sound - one that sounds like a Bechstein in a concert hall.
Thanks for the support. I have a long way to go, but that's the fun part, isn't it?/ Interesting shifting the tracks for effect. Thanks for sharing the tip, I'll give it a try.Holy analysis paralysis batman! Damn they all sound good enough for government work. The performance is great and the audio of any of the tracks is adequate to share the piece with the world. But that's just my get r done attitude. I'm old, not a trained professional engineer like Rob and certainly have loss some of my hearing. Since YOU like the darker sound go for that since your the artist and it's your paint brush. Rob is a seasoned pro at this stuff so I'd take his advice above and get r done!...to YOUR liking...Your creation, . your rules. Good luck! FWIW I sync'd the two original tracks maybe a millisecond apart and again though it sounded great mixed together...Kind of like we do with vocals.
If the video is on YouTube, can you post a link?The honest thing about making this sort of music sound good really isnt the gear. It’s the instrument and the space. I made a video way back where I took a decent single mic and while the pianist was playing, moved it around even underneath, in a normal room in his house and what you hear was not what you expect. Especially close in. Moving to the left or right doesn’t do what a guitar does. Most sound comes from the soundboard not the strings, or at least that’s what it sounds like!
