Studio monitors response curves measured today with REW (input please)...
I learned long ago that buying cheap products that were a little less than perfect, and tweaking them, was always a bit of an illusion. In my office, I run a pair of RCF 5" monitors. I have 5 pairs of them, in flight cases for stage edge fills. For music serious listening, they're just OK, but I know what they sound like, and I know that if I can hear the bass guitar on the E string, then that E will be way, way too loud in the mix. I can deal with it. Tweaking cheaper speakers is just pointless. They are what they are. Same with the folk who spend hours turning a cheap Chinese mic into a U86 and a half. It will always be nearly an 87. For years I toured with an EAW all in one PA cab - big 15" for bass, and a mid and hi unit. Loved them - always sounded good, but when I bought a new, better and mega expensive system, I wished I'd carried on with the old one! The new one was, in every way measurable, better. The trouble was, I liked the sound of the old one. Two boxes, lovely sound, but folk at the front were deafened and people at the back struggled to hear in many venues. Twelve boxes dangling gave the same volume everywhere, but just wasn't as nice. Luckily, people only heard it for two hours, and thought it great!
EAW 650s? I always thought they sounded great.
Today, I measured the two Behringer Truth B2031A speakers, outdoors, plus a third speaker which is the older variant called B2031. Here are the readings. The mic was in the same position for all three speakers (26" away from speaker, pointing at the spot between the woofer and tweeter). Admittedly, there was a little bit of extraneous background noise, such as distant cars, occasional distant pidgeon crooning, etc, but the difference between the readings looks bizzare to me. Speaker No2 looks wild! Only the older variant (B2031, the bottom graph), looks nice and flat (ish). Unfortunately I only have one of those! It's possible that I was doing something wrong during the measurement process. The mic was on the verge of feedback, in order to get the levels acceptable, according to REW.
What does "mic was on the verge of feedback" mean? The mic's input should not be routed to the speakers.
Thanks for that, BSG. I had the mic plugged into channel 2 of the audio interface and used the same channel for output, going to whichever single speaker was being tested. Perhaps that was a mistake, was it?
Input monitoring should be off.
That could indeed have wrecked it because you get weird comb filtering effects that add in spikes to the response curve where they overlap which combine or reject to a degree.
Thank you, Rob. Yes, could well be, as I got much more similar curves from the three speakers today (see post below).
Today, I tested the three speakers again, and got much more similar results from the three Truth speakers. (Probably because the REW setup was more correct). All three speakers were measured outdoors, with mic 26" away for each speaker, pointing to the spot midway between woofer and tweeter. Extraneous nois was just a bit of wind rustling the leaves of a nearby tree, mostly. So today, the three curves are mush more similar. I'm jut very perplext at the drastic lack of flatness. I'm wondering wy these curves are so un-flat compared to other peoples' measurements of this model of speaker. Can anyone suggest why? Image below:
RED = Behringer Truth B2031A (left)
GREEN = Behringer Truth B2031A (right)
BLUE= Behringer B2031 (single older variant, acquired for spare parts)
