Equalizer APO not working in REW...
  • Thread starter Thread starter Ally-007
A
Ally-007
Member
Hi folks. Is anyone familiar with REW and Equalizer APO? I'm trying to compensate for room resonances in my small home studio, using Equalizer APO and REW (niether of which, I am very familiar with). I measured my room acoustics in REW, using a measurement mic and a pair of 4" active monitors. I then used the computed EQ compensation settings generated by REW, and entered them into Equalizer APO 'config.txt', set to affect the output of my Behringer UMC202HD audio interface. I could clearly hear the EQ changes, as I made them, as I had some white noise playing. I saved the changes, and then ran another room test in REW, expecting the test result to reflect the EQ changes. It didn't. Equalizer APO was obviously not equalizing the sound sweeps generated by REW. Then I also noticed that the APO EQ changes had no effect when playing projects in my DAW (Reaper)... but I rectified that by switching from ASIO4all to WaveOut in the DAW's audio device settings. So now, I just need to figure out how to get the Equalizer APO changes to work when running REW tests. If I switch from ASIO to Java (the only other option in REW's preferences), it won't let me run tests. (The 'Measure' button gets grayed-out.) Thanks for any help.
UPDATE: I tried switching for ASIO to WaveOut in my DAW's Sound System settings. That made EAPO work, but encountered major problems with sound quality after a while, so I'm now going to try WASAPI. In order to ise WASAPI, I had to change my audio interface's sample rate from 48000 to 44100, though. Is WASAPI considered okay for use in a DAW?
Do you have any solution so far ?. I met the same one like you
