christiandaelemans
Active member
hey all, i’m finally learning how to use my Tascam m512 board and the tascam 38 i acquired this summer. all is good with the board, there’s some scratches and screeches as i exercise the flows and work the thing like it probably hasn’t been in 10 years, but whenever i record to tape using sensible levels (just faintly going into red, but basically living in the middle of the vu meter), the tascam 38 has extremely quiet tape playback. granted, it doesn’t have NR. i just bought 2 units cheap last night because i’ve heard that it can combat a lot of the noisiness, and i like how it sounds on my 244.
for those that won’t read ahead: basically, my tape playback is way too quiet to be right. it’s either user error in the monitoring stage, level setting stage, or the 38 unit i’m using which i was TOLD was serviced maybe wasn’t. the heads look totally unworn, it was a unit that was barely used.
as i understand it: you go into INPUT mode to track initially, while not using the cue lever, and you stay in mic mode on the mixer while you record. the only levels that matter on the board are your trim, and your fader level. everything else is monitor related or some other facet of sound not related to levels.
then, to playback what you recorded and even to overdub, you go to sync mode, still not using the cue lever, and you go into TAPE mode on that channel strip. you then use primarily the tape trim on the 512 to hear back the tape.
you can also set some buss monitors or aux monitors to tape, but even then, i find it waaay too quiet. the sound of my real-time overdub (which i’m assuming is a function of the tascam 38, it monitors an overdub input as you play it, and you can’t turn it down) is too loud to hear the tape track i’m playing along with.
any help would be greatly appreciated!
