There are a few things you need to consider when doing analog-digital integration. First, you need to make sure your equipment is compatible. You'll need an audio interface that can handle both analog and digital signals, as well as a tape deck that can output a digital signal. In addition, you'll need software that can import and work with digital audio files.
Once you have the necessary equipment, setting it up is relatively easy. Just connect the audio interface to the computer and the tape deck to the audio interface. Make sure the deck is set to output a digital signal (usually by selecting "digital" or "PCM" on the menu) and start recording!
When importing the tracks into your DAW, make sure to set the project's sample rate and bit depth to match those of the original recording. This will ensure that you don't lose any quality in the conversion process.
Jason Hook. Audio Enthusiast and Software Developer
Remove or Isolate Vocals from any Song https://www.UnMixIt.com/
