TimOD
Active member
How about some Deoxit into the XLRs? Shouldn't that help clean up the innards of the plug?
Do no harm at all friend! But, AFAIK Deoxit is not a lubricant, WD-40 is. Note! I am not saying FLOOD the fekkin' things! Just a smear on the mating surfaces is all that is needed and not just the lekkrikal bits, the shells jam as well.How about some Deoxit into the XLRs? Shouldn't that help clean up the innards of the plug?
Yes, I would think De-Oxit is a degreaser as well as the other cleaning qualities it has and will therefore leave mating metal surfaces 'squeaky clean'? Metal to metal needs a lubricant, not much but some. You could probably use a trace of any mineral (clock?) oil or vegetable oil? We are talking about a very small trace here.So, you can use a bit of WD40 in a case like this? Of course don't flood it--maybe a little on a rag and wipe the plug, right? I figured the Deoxit would clean the plug and jack a bit and make it work better.
