Ok, realize ive not owned one, but have had familiarity with most tascam gear.
If you had this in a control room behind glass with the talent on the other side, you wouldn't be monitoring on headphones. So they'd be out if the picture.
Only the talent would have a HP mix that was run off of a seperate HP amp.
If everyone was in the same room you'd not use the monitors at all, and chances are you'd use a HP amp as well .
Thanks for clearing up the question I had about the soundcard.
It sucks that it doesn't have a HP volume.
Now when you are using monitors, when everthing is at unity running around 0db on the meters, is it still too quiet?
Shouldn't be. Should have a healthy level.
I know with a 100 watt Bryston, if I turn up my output fader 1/3d of the way up, my NS10s are loud!! I don't dare push it up more.
With the Yorkies and the alesis, you should have some volume out of them.
Edit:is that TC vol control tied in somehow??
Just scratching ny head on this. It seems you should have similar volumes.
So forget about the hp for a minute. Can you get good volume out of the amp and speakers?
I can get good volume out of my MON OUT jacks (on the 388) going into my speakers as long as I turn the MON/PHONES knob on the 388 up all the way. Like I said, though, when I do that, the headphone jack on the 388 is completely unusable because it's ridiculously loud.
The TC Level Pilot is basically just like an attenuator before the power amp (I think). I don't know for sure, but basically it has the same effect as me reaching down and twisting the knobs on my power amp. If I were to take it out of the path, then, with my power amp on full, I'd blast myself to oblivion.
That's why I was a little confused by your statement about how you "always run your amps full bore" and "control the level at the mixer." I've always read that the best signal-to-noise ratio on a mixer is attained when most of the faders are near unity gain. If I were mixing a song and had all my faders around unity and fed that signal to my power amp without the Level Pilot in the path, it would be way too loud! It's hard to remember exactly, but I think back before I had the Level Pilot, I would run the output of my DAW through a little Behringer mixer before going into the amp, so I would control the level from that. In other words, I would use that to turn it down before it hit the power amp.
And while that sounds like what you were saying ("control the volume at the mixer"), that's actually a second mixer in that system, the first being the one in the DAW. If I were running a tape rig and using only one (main) mixer, wouldn't you want to run it near unity gain to get the best sound?
Or are you saying that you're controlling the level of the
monitor mix (not the main mix) with another knob, and that's the one sent to the amp/speakers?
See, I think one of the main issues is that I've always made it a habit of just listening to the stereo mix -- not the monitor mix. I never understood how to do it back in the day ... and now that I'm trying to figure it out, I obviously still don't have a total grip on it.
It seems as though it should be a simple thing, but now that I'm trying to actually put it into practice on the 388 (and also the 246 --- see my other thread "Tascam 246 mixer questions" for another somewhat related issue on that machine), I'm running into all kinds of little bumps.
The 388 has an AUX BUSS and EFF BUSS in addition to the dedicated monitor buss. With regards to the statement about the talent having a HP mix off a separate HP amp, are you talking about using one of those (AUX or EFF) sends to create that mix? I have two headphone amps, so I could do that.
