rayc
retroreprobate
Here's a file of real bass & guitar PLUS fake drums.
Fake Drums - Band In A Box + Real Player which is an add on that came with the box.
My wife bought me the program a couple of years ago & I didn't need it because I have a DAW and can play bass + a little guitar. I needed fill in drums one day so I thought I'd look in the box.
It has Midi drums as well as Real player drums but RP doesn't have as many options or speeds.
For this project I used an older drum track as a metronome and recorded a bass line.
I exported the bass line & BIAB imported it.
Since I was in there I used the chord feature so as the bass was imported BIAB scanned it and blocked in chords on a chart.
I clarified where the 1st bar started and checked that the chords & bars matched the audio tweaked a few bars and then sent the chords into BIAB properly. At this point in time I could've taken the option to midi map the tempo etc but didn't as I wanted Real player drums.
I opted to dump the audio bass file at this point as I didn't want anything to give me grief inside the prog.
I went through the chords and put markers in where the progression changed V C V M8 etc.
I then auditioned drums styles - there were only 8 that matched the tempo.
I auditioned them and then allowed it to play through the one that I thought best fit.
NOW, here's where the amazing thing happened...
I minimized BIAB & booted up Reaper.
Set a new track for drums reduced Reaper and pulled up BIAB. I selected PLUG IN in BIAB &them start PLUG IN at which point BIAB shrinks to a smaller dialogue box I pulled up Reaper again and BIAB hovered over the top.
I then clicked Drums on BIAB and dragged the cursor to the drum track.
BIAB & Reaper talked to each other for about 3 minutes and then a wav. file of the drum arrangement appeared - and this is important, in a single stereo track in Reaper.
I then Selected BIAB Plug In & turned that off & minimized in again until I needed to confirm, redo or close it.
From there all I did was drop a little compression on the drums.
DONE.
BIAB is really for people who can only sing or do very rudimentary instrument stuff (I can't sing) as it will generate full band backing with solos etc. I just use it for sketch drums.
DONE.
