G
Greg_L
Banned
"Mic friendly volume" isn't a thing. Can you overload certain mics with loud amps? Sure, but then you're using the wrong mic. And a 1w amp can still be loud enough to piss off the neighbors. A single Vintage 30 speaker pumps out 100 decibels at one meter from one watt. That's loud enough to get you evicted in an apartment. So where's the little watt advantage if loudness is a concern? Everyone wants to CRANK their little amps because they can. Cool, you're potentially making 100 neighbor angering decibels. And the tonal problem with that is that you're not even making the speaker work, and a speaker working hard is a big part of the final tone. Power amp breakup is great, but if the speaker stays stiff, then what are you accomplishing? You might as well just use a sim. And on top of all that, what are you going to pair this little amp with? A little cab? Great, you just cooked up a recipe for little guitar tones. Maybe that's what you want, and that's fine, but if you want a big sound big gear does it with no tricks necessary. You can't fool a microphone. It will capture what you feed it. Feed it a big sound if you want a big sound.Lol. Never said you weren't correct. My contemplative hypothetical thinking process was a 1W/2W/whatever valve amp is gonna crank out gnarly tones at much lower & mike-friendly volumes. I'm talking recording scenario here, of course.
I think it's baloney because I've tried both ways, I've heard lots of other people try both ways, and it's just common sense that a 1w amp cannot sound like a 100w amp. That's not to say that you need a 100w amp for everything. But if you need or want huge rock and roll amp sound, a little watt amp doesn't do it. Can you fake it? Maybe. If you're into that sort of thing, sure, add tons of layers and reverb and other tricks.To be fair, this ain't my idea. It's a common tip around, to use low-wattage amps/practise amps/etc in the studio. Now, whether it's all baloney as you seem to insist... is another matter.
Of course I love gut-mashing cranked-to-buggery rockin' amps like the next guy! I guess I question the idea that sticking a mike up to this volcanic cock-holocaust is going to capture in any real way this organic live vibe? But... I'm not really siding either way in the argument. To be honest I think both sides have good points. "Loud & defined" may indeed capture well, and my idea of "blasting wind" into the mike may be erroneous. I guess the question is, how does it compare to a low-wattage amp miked up? What is this anomalous "power vibe" thing that is somehow captured by a mike onto a digital track?
[ducks in advance]
All I can suggest to you is to try it for yourself. You seem to be trying to talk yourself into a little amp. I'm assuming you have very little experience with either method of amp recording, so just try it and see. I think little watt/low volume lacks most of the good things found in great guitar tone. They're fine for dicking around, but they don't make any sounds I'd want live or recorded. YMMV. I tend to get the impression that people justify little amps based on things like cost, size, and weight. Valid concerns for some people. Some people might give up tone for the ease of flinging around a 1w practice amp. Fine, whatever. For me it's just about sound, and little amps don't sound nearly as good to me as big amps. Maybe you'll think otherwise, or maybe you'll agree, but you do need to try it for yourself..
