Jay C
I want to change the speakers in my amp, Blackstar ht 60 stage. 2x12. i know i need 16 ohm speakers , but what about watts? does it matter how much? the amp is a 60 watt.
Speakers have a big impact in how the amp sounds. Go listen to some clips on different speaker websites and identify the characteristics that you like and dislike.
What are the speakers in there currently? Celestion makes some good shit and some bad shit. Which ones do you have?
And why do you think you need 16 ohm speakers? I would go with two 8 ohm speakers in series giving you a 16 ohm total load. Then you could add another 16 ohm cab and run them together with an 8 ohm load on the amp. 16 ohm cabs are more versatile.
right now when i use the cab, i plug the internal speakers into the 1x4 ohm slot, and the cab into the 2x8 slot. i wasn't using the right outputs for a few jams and almost shit myself when i discovered what i had been doing.
you're prolly still not using the right outputs.they are seventy/80's. i'd like something with a little less mids i guess. these speakers seem honky to me. i have been listening to comparisons on youtube and i think i'm close to choosing. also i do already have an 8ohm 4x12 cab that i like to use when im jamming with my drummer, ( 6x12 sounds lovely.) on the back of the amp are 5 different outputs for different ohms, i probably should go with a 4ohm load,but then i'd have to spend a week figuring out what inputs to use without blowing up my new amp. lol.. right now when i use the cab, i plug the internal speakers into the 1x4 ohm slot, and the cab into the 2x8 slot. i wasn't using the right outputs for a few jams and almost shit myself when i discovered what i had been doing.
First ..... am I right in assuming the speakers that are in it now are 16ohm which would be why you say you know you need 16ohm speakers?
If the speakers in the amp are 16ohm ..... then they're gonna be wired in parallel without a doubt so they would have a total load of 8 ohms.
So the internal speakers should be plugged into one of the 8ohm outs.
And then the 8ohm cabinet should go in the other 8 ohm out. Yes ..... that gives you a total load of 4 ohms but that's why they would have 2 8ohm outs.
My mesa's have the same 5 outs on them. I actually called Mesa and they told me it didn't much matter which ones I used and I should try them all and see if I liked one better than the others soundwise because they'd all sound different.
