E
		espritbonne
Note: I couldn't post them earlier, but the links for the audio files (before and after the hard-limiting) are now posted below.
Thanks so much for any input regarding my settings for hard-limiting a voice only mp3 file. I’ve been a voice actor for over 25 years and have produced most of my own audio during that time. Originally I voiced from the radio stations I was jocking at, but in 2001 I built my own studio. Because I was hosting a talk show in Washington DC at that time but living 90 minutes outside the city, I wanted to be able to do my show from home via ISDN whenever necessary. So I built my home studio to be similar to the set up in the On Air studio at the radio station: an ElectroVoice RE20 mic, through a Symetrix 528e processor, using a Mackie Board and a DAL Digital Deluxe soundcard.
Many of my VO clients like me to send them nearly flat audio, for them to tweak as they like. But I’ve started voicing audio books, and my clients now have varied requirements. I’m currently voicing a book that requires mastering, and since it’s voice only audio, I’m hoping it won’t be too difficult for me to figure out what sounds best. But I’ve never totally trusted my ear. I’ve always had a sibilant S challenge, and my voice is lower than many females, but if I work too hard to correct those, I create other, possibly worse issues. Hope you can spare a few minutes to check out the links below for my :40 excerpt from my original .wav audio (as recorded, and using their requirements: 44.1kHz, 16 bit, stereo) and compare it to the hard-limited version saved (as they require for finished audio) as an mp3, at 192kbps. For the hard-limiting, I kept the max amp at -6 dB and boosted by 6 dB, with the look ahead time at 7 ms and release time at 100 ms. Thanks again, I really appreciate your time. And please don’t worry about hurting my feelings, I’m tough.
Here's the link for the original .wav file:
www.debraleigh.com/AsRecorded_AudioBookExcerpt_44.1kHz16bitStereoPCMwavfile.wav
And here's the link for the mp3 file in the format the audiobook publisher wants, with the hard-limiting:
		 But nothing ever seems to solve the problem. Right now, my Symetrix 528e De-Ess frequency is set at about 3 o'clock, maybe 3:30. The threshold is set between noon and 1pm. When I try to De-Ess with software (any software I've ever used) I seem to only make things worse. By that, I mean the other problems I created while trying to lower the sibilance were even worse than the ssssibilance. (So you KNOW they were bad!) So I gave up trying. Do my Symetrix settings sound to you like they're exactly where they should NOT be? Thanks again.
 Then I re-read your post, and realized what you were saying. Can't tell you how much that means to me, taking a moment to reconsider all this from the perspective that maybe I've just been focusing understandably more on the creative side of my work than the technical. Thank you! At the same time, I know I need a better understanding of what all these little knobs and meters really DO, and how they relate to each other. I'm so indebted to you and the others here who have patiently shared your ideas and knowledge. You've inspired me to stop being intimidated by the technical side of my work, and instead, just enjoy exploring it! Thank you for that, and also for your kind comments about my VO. And for the info you sent, much appreciated!
 Then I re-read your post, and realized what you were saying. Can't tell you how much that means to me, taking a moment to reconsider all this from the perspective that maybe I've just been focusing understandably more on the creative side of my work than the technical. Thank you! At the same time, I know I need a better understanding of what all these little knobs and meters really DO, and how they relate to each other. I'm so indebted to you and the others here who have patiently shared your ideas and knowledge. You've inspired me to stop being intimidated by the technical side of my work, and instead, just enjoy exploring it! Thank you for that, and also for your kind comments about my VO. And for the info you sent, much appreciated! The funny thing about forums is someone else will always come along and say 'you told her to do what!!!?'
