T
TheRealRoach
Hey everyone,
I'm going to be doing my first full band with the 388 starting this weekend and was wondering how you handle headphone mixes for the live floor. I can see two options:
A) I was hoping to run the Aux Sends pre-fader out the Aux Out jack to my headphone amp. But,i f the keyboardist (for example) wants to punch in a few bars then the only way I can think of doing it is to switch all channels to RMX input, and keep the one keyboard track in Mic input, but with this configuration he will not hear his own previously recorded material leading up to the punch.
B) The other option is to use the monitor outs for the headphone mixes, which seems ideal for the live floor given the above scenario, except for the fact that I would prefer if the control room didn't have to share the same mix as the headphones.
Any thoughts?
Mike Rocha
Any thoughts?
Mike Rocha
and I'd like to know the answer, but as long as the keyboard is being input on a channel that is not the same as the track to which the keyboard was first recorded, you may be able to just use the AUX buss...you see in that scenario let's say the keyboard was recorded to track 5 and the keyboard is input on channel 3...well, to monitor the playback you'd be switching channel 5 of the mixer to source RMX (tape) and you'd have the AUX knob turned up on that...that satisfies the need to hear the already tracked material right? And if the keyboard is connected to channel 3 and the AUX knob is turned up the keyboardist and the band should be able to hear the live keyboard source as that channel will be sourced to the LINE input. So both sources (the original tracking of the keyboard AND the live keyboard input) will be available to the AUX buss, and channel 3 with the live keyboard will be grouped to PGM 5. Setup like you would for an overdub and as soon as you hit REC the channel 5 source (which is track 5) will cut because now the track 5 head is recording and won't playback anymore, but that won't effect the channel 3 input of the keyboard which is routed to track 5 AND to the AUX buss.
