themdla
i have this question posted along with another thead i started about a different subject and figured this question may need it's own topic.
i have read a few articles over the years that said andy wallace and other engineers believe that it's easier to get tracks to "sit" well in mixes quickly with compression on the master buss. as well a friend on mine who is a successful engineer always uses outboard buss compression and convinced me to buy an outboard 2-channel compressor.
everytime i've tried to use it though i am constantly adjusting it not really knowing exactly what i'm trying to achieve with it. i assume based on my limited knowledge of compression that i'm trying to reduce the dynamics and peaks of the overall mix in order to push the loudness, in something that seems to me akin to mastering.
however i don't think this is proper usage and i guess my main question is....
do you use buss compression during mixing?
and
when using buss compression during mixing what are good starting settings/effects/techniques to work with traditionally?
(obviously this will differ based on the content and its initial recording levels, however i'm assuming ideal -18dbFS signals across the board).
and
