O
ofajen
Daddy-O Daddy-O Baby
How does the reversing idler mount? The rotary guide on the Ampex 440-8 is held to the transport plate by a center bolt, but there are three fat set screws underneath also so the guide actually sits on a fully adjustable tripod. Good and bad but I wondered if there was any adjustability like that on your reversing idler...not that it should need it with a deck plate like that!![]()
It just uses a center bolt and the base mounts flush on the deck plate. No set screws, however. Once you get it almost tight, it starts to slip on the deck plate surface, so it's easy to just rotate the whole thing with the Allen wrench while watching where the tape goes on the idler. I've got it in a much better alignment, and the response is radically different, even without doing a proper alignment, which I will.
I also have some extra audio cards (#1 bias/erase and #4 record preamp) so I do have some options if those cards seem flaky on the machine. I did already pull the lower #1 card. It just wasn't doing the job biasing the machine. The annoying thing right now is that the left channel #4 (I think) works OK on playback, but I don't seem to get the input signal. I may swap that card out, too.
Cheers,
Otto
