D
dj9fingers
Hello, I am new to this sight and have a troubling situation with my MSR 16. I was recording some vocal tracks tonight and as the tape was running the tension roller on the right side started to bounce up and down. After looking a little closer I noticed that the rubber on the pinch roller and the tape counter were soft and sticky. The tape was sticking to the pinch roller and popping off creating the bounce. Both the rubbers were starting to melt! The rubber on the tape counter (I think that’s what it's called) was really bad. It was so soft it was sticking to my fingers like tar. Weird. I ended up having to remove the rubber. The pinch roller was not as bad but very soft as well. Before I start my recordings I always clean the heads with a Q-tip and rubbing alcohol and have never had a problem. I did spill some rubbing alcohol on the carpet tonight three feet away from the deck. Could this be the cause of my meltdown? Is rubbing alcohol a no no? Does anyone know where I could find new rubber?? Thanks...
