ZoSo58LP
rock guy
Ok so my prized possesion '89 USA strat has always played fine...until recently I noticed that my low E goes outta tune often and when i strike it, the tuning varies..like i dont play very hard, and it can be perfectly in tune, but when i hit a chord, the E goes in/out of tune...so its tuned right, but hitting it makes it go higher....and i cant f'in stand it anymore...it just sounds like ass and this thing has always played fine with 10's....do i need 11s?!?!!? i cant solo too well wiht them! please help...thanks!
so okay, i like the idea of applying some machine oil to the roller nut. i'm using a set of fender superbullets, 10 guages...always have, and never had this problme. ive been rocking half step down lateley, altohugh this HAS happened with standard as well. ive noticed that whenevver i do some crazy low E bends, with a pinch harmonic or something (ala zakk wylde), it REALLY comes out of tune. OK so light, i did the trick by pushing the string down before the nut. at first, it went out of pitch. then i retuned, did it agian, and it was fine. again was fine. then i tuned to drop D, did it, came out. did it again, came out. again, and was fine from then on. do you think i should lube up the nut on the E? also, ive got
