A
adrianhouse
Correction - it does say "12V DC in" on it (as I posted above)
.3. absolutely NO harm can come from an adaptor that is rated higher than necessary in terms of amps.... period....that inrush idea is bullshit!!!
1. there's no regulation in an adaptor....
what i now know is you haven't a clue....correct the circuit will not draw more amps then it needs its not posible by the facotrs of the components used
there are regulated ac to dc adapters and regulated and filtered ones so that is not true. Radio Shack sells regulated ones. If it's unregulated and has higher current you can damage equipment even if polarity is right. The voltage swing not current on say a 9 to 12 volt unregulated adapter could be as high as 20 volts at power up do to not having a current load till the circuit is turned on which can fry chips rated at say a max of 15 volts. Where A regulated supply will stay a consistant voltage and be perfectly safe and a regulated and filtered supply will be best cause there will be no ac on the dc lines thus less noise in the supply and in your audio path
now you know
regulation is about sustaining the voltage at a speific value... NOT about current.... specified current in an adapter is an indication of it's max sustained capacity... as long as it's rated somewhere above what the unit draws you'll be fine... the regulation and filtering are typicly inside the unit NOT the adapter... in it's most basic configuration this is simply a zener diaode and an electrolytic cap... and i do have a clue... i spent years as a pro technician...
I just picked up a Zoom GFX-5 multi effects unit . It was a manager special. The recommended power supply is 9 volt . 300 ma. Negative tip.
Can I use a 1.0 amp , 9 volt , negative tip wall wart and not damage the Zoom GFX-5. Will a 1.0 amp cause damage to a .300 amp unit ?
Thanks for your help. I am surprised that Zoom would sell the transformer as optional equipment!
tabletop boxes often used for experimentation or customized personal use...
look dip-shit... on the one hand i couldn't care less... but maybe you ought to do your homework... just taking the first thing from your personal list....
homework? I JUST TOOK YOU TO SCHOOLmaybe you ought to do your homework
