Hello everyone, I've been doing a video and audio podcast for about 4 years, streaming, I also do voice-over for videos, and I'm looking at the Audient MkII as an upgrade, here is what I currently do:
I've upgraded a lot over the years but at the moment my current setup is as follows:
- Shure SM7B w/Dynamite lifter
- Focusrite Solo
- DBX 286s
- I also have 4-inch acoustic foam covering the walls, and 18-inch thick bass traps in the corners, with a thin layer of acoustic foam covered in a black-table cloth covering the hard surface of my desk to reduce audio reflections in a carpeted room.
- Mogami xlr cables
For what I do, this is better than many, but, I've been reading lots of reviews on the Audient MkII M4 and M14, and the general consensus is that the pre-amps are fantastic for the cost, and a giant improvement over my Focusrite. The thing is, I plug my mic into the dynamite lifter, right into the back of the dbx 286s and from there, into the Focusrite at line level with gain on zero on the focusrite. So, from my understanding, I'm basically not using the Focusrite at all, other than to put the sound into the PC. With that in mind...
Would the Audient MKII M4 & M14 have improved preamps over the dbx 286s? Also, if it does, I think I'd still want to route the mic through the dbx 286s the same way, but just use the bypass preamp switch on the DBX, and basically use it for the de-esser and subtle noise gate, which I guess means, the DBX would have to be secondary then... If the DBX 286s has better preamps still, then I won't even bother buying the Audient device.
Would appreciate any insight, thanks!
- Focusrite Solo
- DBX 286s
- Mogami xlr cables
