CoolCat
2488 test dirvin' ~29day?? damn time flys
yes,thanks.. i've been there too.
your a bit ahead of me on the 2488...i was just test drivin' for 30days.
I think my 30 is up +/- a few days.
TRACKING: A++++
To date the 2488 is awesome at Tracking. (user friendly=awesome).
It accomplished one of my Upgrade goals>>> more tracks.
TECHNICALL/SPECS: A++++ 24tracks/24 bit....$1,000BUCKS..c'mon it's sweeet.
Brief summary of negatives:
MENUS: The reverbs ok, the compressor is different but liked the RNC better, the EQ sounds ok-it works, guitar/channel/effects imp noisy& don't care for, the sliders seem kinda "short" and can really cut-off your fade out, Mastering Effects weak?? no limiting only Compress or Expand, CDR can't upload.
MY FIX: ADD A CHANNEL STRIP/Outboard- but I just record 1,2's...no 16inputs needed. that'd be $$$..damn.
Didn't get rid of my TCM300 Reverb either, but the 2488 Reverb is alright I guess...
When the TRACKING is done, and you've played with the Pans etc...and relaized you can't figure out the menus as far as applying different compressions and effects on the tracks...it's time to PREMASTER.
This is really just recording the TRACKS/MIX to HD/Temp file perse.
You press REC/ while mixing and the End result is a PREMASTER.
So then you sit back and play the PREMASTER a few times, hitting the speaker selector from A to B... asking do I like this mix??
if so, or if you have to run errands lest your wife brow beat you and ruin your day with other images....you burn a CDR quickly...MASTERING, I mean.
I was really let down on this section, I didn't expect the world...but damn a few limiter presets...or something you know??
all it had was COMPRESSION or EXPANDER.
for a home recording gearhead...i wanted to have somemore Mastering stuff.
I've read the pros leave it all for the MAstering Houses, which is probably why the 2488 didn't spend much Eng talent on this section.
BMW..hope you keep posting on the 2488.
Whats your Pro's and Con's on the unit???
Do you use the Guitar effects?
Is the compressor good?
damn.....too much coffeee again, sorry for being so long.
philboyd studge said:Best place to ask is here:
http://www.tascamforums.com/
TRACKING: A++++
