2488 - Vox and Acoustic
Had a good little weekend with some one to one comparisons.
Material: 1 verse of a Vocal and Acoustic only song.
TEST GOALS:
Question: does the adding a small condensor improve?
Question: Is the Channel strip improving and justifying the $$$?
RESULTS:
Voting was done by "blindfolded listeners" hearing this "partial song snipet" over and over....
each set was called out as #1, #2, or #3.
The "consumer listener" would say which they preferred to hear, or sounded best.
I would mix up the order also, #1,#2,#3... would change.
#1 SPB1 only, would be changed to #3 or #2...random listening orders.
Recording: Vox and Acoustic ( ALL FLAT/DRY except for Joe Meek#3)
#1 Track1) SPB1 Only
#2 T2&T3) SPB1 + 991
#3 T4&T5) SPB1>Joe Meek Channel Strip + 991
Listener results:
First pass voting- Joe Meek was voted BEST of group. Unanimous.
But the addition of
the MXL 991 got the judges votes KEEPER (Oh yeah!!! thats better!!!leave that there whatever it is!" responses)
+ Joe Meek is a positive addition to the 2488.
+ Also the small condensor, MXL991, helped considerably.
(for ~$45 the MXL 991 is here to stay.)
Partitions: TEST 2
Question: lets see what the 2488 internals can do?
TEST KNOB: 2488 internals added (comp, Eq) vs the Joe Meek VC1Q strip.
I sweetened the best I could to get the same sound, and it was closer.
Apples to Apples somewhat using EQ + Compression only.
TEST 2
#1 Track1) SPB1 Only > Internal 2488 EQ+Compressed
#2 T2&T3) SPB1> 2488EQ/Comp + 991 ( scd/acoustic comp/flat ok)
#3 T4&T5) SPB1>Joe Meek Channel Strip + Track5=MXL991 (flat/dry)
Again I replayed the snipet tune several times. Muting ON/OFF and the listeners would respond if they liked #1,#2, or #3.
Results:
Again, Meek had the best blindfold results.
same results nearly unquestioned, however
instead of a 100% unanimous results,
the 2488 with eq/comp actually got a couple votes. 2 of 8 plays.
Again unanimous,100%, the added small condensor was an improvement.
In the End:
1) I was actually hoping the used Joe Meek VC1Q would fail, so I could return it for $400+ and buy a whoooping $$$Microphone.
unfortunately, I will have to go work some overtime to keep it!!
I did have it setup nicely (pat on the back to self)
Joe Meek Notes:
- It has a horrible manual.
- its easy to fhkng lose your SWEET SPOT.daaang.
- I spent several hours on it today, and it can make horrible noises such as distorion with output too high, SSSSHHHHHHSSS noise if comp is setup another way.
but when its there its there, and I can understand why people love their Joe Meeks when you "get it".
2) The Gang here mentioned the small dia condensor in addition to my SPB1,
i picked up a MXL991 becuase it was cheap, and so am I. Actually the 990/991 combo at $89.
My Non-professional advice,
I did notice positives to the 2488 Compressor, it has the
faster attack,limit or knee it's nice more like my old RNC i sold.
The Meek won hands down, I can't argue this as I was there.
Required 2488 SLAM:::
RECORDING MAGAZINE- Feb 2005
Tascam 2488
Negatives mentioned must hold the Rewind+Stop to RTZero.
