miroslav
Cosmic Cowboy
So, if I sing 6" away from a mic, then turn up the preamp gain, my voice will be amplified. Any other noise will also be amplified, but if it's farther away than my voice, the amount of amplification is much smaller than my close voice.
You're making assumptions about the distance of the noise-to-mic.
Just because YOU step back away from the mic it doesn't necessarily mean the noise is also stepping back equally...unless it's a very localized noise, in which case just pick up the mic and yourself...and move away from it altogether.
If you step up to the mic, then you've increased your signal to noise without touching the preamp gain.
I can know exactly want I might want in a function- I just have to keep looking up which they're called
So from a mastering standpoint, at least, IS that the preferred alternative to normalizing?
