Sounds like a means of consolidating and then rendering to a new working track. Not sure with your app but in Sonar for example there is 'bounce to clip- consolidates and processes down to one in place of the existing clip, or 'bounce to track- consolidates to a new track. I believe though if the source clips or track is just muted' it doesn't unload processing it (could be wrong.. we have to 'Archive the old track to free it from processing.
Again to my way of thinking if you have a gain change target it mind there's a half dozen places or ways to do it, and peak normalize would seem to be the most haphazard way to do it. But then I also don't see the utility of the alignment to peaks as a track prep method.
What lets say we have a string of guitar overdubs ready for assembly for mixing. A few happen to have some nice sharp peaks, some others don't. How is aligning to their peaks making the track fall in to your new better leveled' nominal read to mix state?
hmm... i think, not sure, but i think u sort of misunderstood me there...
i'm not concerned at all about lining up seperate tracks to have SIMILAR or shared peak levels. The -10 to -7 dB range I mentioned simply seems to be a good, strong range for my recording signal to provide an adequate noise-to-signal ratio, that's all. So, my process is, to usually record at like -12 to -10 dB strength for the GENERAL level (is this called RMS?? meaning, the average level of the take?) Anyway, with the average level around there, I usually end up with a take that has some peaks and they usually spike around -10 to -7 dB.
so my compressor then reduces THOSE peaks back by maybe only a few dB and then, one way or another, I raise the gain. I was simply speculating whether or not normalising was another way to bring the gain up, although, as far as I understand it, all it's doing is the same thing as raising the fader?? Which I'm already doing, so what would be the difference, one way or another?
All this I just described I do simply after I have recorded and edited the track. I then do these minute processes to simply create a track with a strong, clean, somewhat controlled signal (reffering to the comp here) with a good amount of head room before moving on to recording the next instrument, track, whatever. I, at this point, am nowhere even close to thinking about mixing so my answer to ur question is that I do not know how it may help me mix as I'm not using it as prep for mixing, simply printing a strong, pre-processed take to track, if that makes sense. LOL
So I'm not doing this to get ready for mixing besides getting the tracks to read at a strong, coherent level. Does that help?? Not quite sure how to explain better, sorry...
