jdier
DISCLAIMER:
OK, my project is low end, low budget. I am doing this for a buddy in exchange for his help on another project. This is the first thing I have recorded and engineered and mixed and I am doing it all in our new home studio. However, I want to do as good of a job as I can...
END DISCLAIMER
DISCLAIMER 2: I posted this question at another site and the replys were of high quality, but low quantity. I am really wanting to know how far to take my mix, I am feeling like I cannot get much closer than I am with out doing things that I have always thought would be done by an ME.
I mix what I have using as little EQ and Compression as I can. I worked to get good sounds during tracking and now I am just using effects to help clean up and even out the mix... When I am done, I feel like I am a little weak on low end.
If I jack up the kick, it overtakes the mix (or sometimes puts me 'over' (if that is the right word... ~my meters peak~)
If I put up the Bass (upright) it also makes me peak out.
I have resisted using compression on the bass and kick since the players were very even and played very well. The few places where a single kick or pluck drives the meters over I correct with a volume envelope.
So, do I just go in and eq/compress the bass and kick until the lowend comes together, or do I leave it like it is and let the mastering house (read: 'someone smarter and more experienced than me') fix it with higher quality EQ and Compression?
Or, perhaps, is it a little of both? My hesitance with the EQ and Compression is that, as a new user with limited experience, I could wind up doing more harm than good, and, for the most part the mixes sound pretty good to me...
I know mp3 is the not best way to hear this, but you CAN hear my problem here...
Bear in mind, if you really crank it up, it is all there, but in my mind, a good mix is one that sounds correct across a large sweep of volumes.
Here is a link to an example:
http://www.soundclick.com/bands/2/danwhitakercountrybandmusic.htm
While ALL of the songs have the problem I think 'the fool' is the best example of my situation.
Thanks in advance for the help and direction.
Jim
END DISCLAIMER
Jim
You're just starting out? LOL! If that's starting, I'll be 75 before I have the balls to post one of my mixes. Thanks a lot pal.
