T
Thatupstateguy
As for the original question in this thread,..... it could be lots of things, ...from loose solder connections to bad tubes,.....
For my two cents worth,...... start simple and work up,... meaning,...
start by jiggling parts,.... cords first, could be a jack,.... then switches,... volume, tone controls,... then jiggle,... or just move the tubes in their sockets,.... do not worry about fingerprints,.... not really an issue,....
if crackle gets worse, or changes with any of the above,... you found the part that needs work,.... if not,... then take it to a guitar amp tech,..... you have exhausted the non-tech methods of locating problems,.....
Touching the tubes with extreemly dirty hands, or grease,.. will indeed shorten their life,.... but since they last about 10,000 hours or more,.... under normal use,... that is if they are good quality to start with,....then shortening their life by a few hours is no big thing,...... unless you are talking about something like a 300B Western Electric or something like that,.... (they go for about $400 ea) and it is just a normal easily replacable, and available tube,... 6L6,12AX7 or some other common one,... don't sweat it,..... so you will lose a days use over 15 years ,....... if you touch it and leave a print,.....
I have changed tubes on hundreds of amps,./.. and never once used anything but bare hands,....
as for the crackle sound,.... I recently had an amp that did the same thing,..... it was loose soldering on the tube sockets,......
from trying out so many different tubes,......
Get new old stock if you can,.... old RCA, or Phillips,..... Mullards or Telefunken if you can afford the best...
GT is making some big strides in tube designs, and is also worth a look,....
Steve
Steve
