L
		larrypatterson
I have been using a VS-880-EX for about a year and have 32 songs recorded on it.  So far I have only "Mastered" them to analog tape, but want to put them on CD.  I also badly need to back up my data and remove some of it, as the hard drive is almost full now.  I am debating whether to buy a VS-CDR-II for data back up and CD burning, or use a Zip drive for back up and buy a CD recorder for mastering. I know the Roland VS-CDR-II Burner will put my songs on CD, but do that, first I would have to bounce my eight tracks down to two, which is a pain in the butt I don't really need.  I want to retain the flexability of adjusting pan and volume of all tracks during mastering.  Using a CDRW disk on a CD recorder I can re-do masters until I am satisfied.  If everything is mixed down to two tracks, I have to go back and re-do that mix, before I can try an altered master. Plus, many of my songs have been "Pitch adjusted" from 44.10 to 46.79 (up one half step) and I don't know if the VS-CDR-II will see that as a change in sample rate (my guess is that it would), which would be a problem when the VS-880-EX builds the temp file it eventually transfers to the VS-CDR-II.  I don't know if this would be a problem going to a CD recorder.
Reading the data on CD recorders like the Tascam CDRW700 and Marantz CDR500 or 6050 give me the impression that I could take the digital out from the VS-880-EX directly to the CD recorder and "Master" just as I have done to analog tape. This would allow me to retain control of all eight tracks during mastering, just as I have done when going to analog tape. However, other sources indicate that I would have to mix to DAT first, or use the analog inputs on the CD recorder. What is the real story? Can I master the digital output directly to a CD recorder? Or does it have to go to a DAT first? Also, would my "Pitch adjustment" bge a problem going to a CD recorder? I know they adjust input sample rate to 44.1. Would that negate my pitch adjustment (slow it back down)?
Also, is the Zip drive a satisfactory method of back up, or would I be better off with the VS-CDR-II for back up, even if I want to use a CD recorder for master (do I need to buy both?). Zip disks ain't cheep! CDs are.
I hope some of you guys out there can shed some light on this, so I can get on with it.
Thanks,
D. Larry Patterson
Thanks,
D. Larry Patterson
