C
Colour
As the title implies, I have a Vox Pathfiner 15R amp that has some unwanted hissing and bzzing sounds.
To start off with, I'm playing an Ibanez AF84E (hollowbody with a minihumbucker) with the tone and volume controls all the way up. The lead is coiled. I sit close to the amp, usually within four or five feet.
On the amp, the Gain and Volume knobs are little below half; the Boost button is off; Treble, Bass, Tremolo Depth and Speed, and Reverb are all off/at 0. Nothing else besides the lead is plugged into the amp.
When I turn the amp on without the lead plugged in, there isn't any noise. But if I get close to the speaker, I can hear a quiet hissing sound.
Then when I plug the lead in, there's a bzzzing type of sound. Finally, when the guitar is plugged in, there is a slightly louder bzzing sound, but it gets a little bit quieter when I touch the strings, pickup, etc. I assume that indicates a grounding problem on the guitar. If I turn the guitar volume control to 0, the bzzing goes away completely.
The amp setting described above are what I usually have on since I mostly play at home. But if I turn any of the amp knobs up, the bzzing gets louder and shaper. I tried two other leads, but the bzzing is there just the same.
There is probably a grounding problem with the guitar, but my guess is that the amp is part of the problem. Correct me if I'm wrong.
I think I've described everything important. Anyone have a similar experience or a suggestion for getting rid of the unwanted noise?
I'll look into the issue by researching online and maybe with talking a luither. And also getting a friend to try his guitar out to see what kind of noise, if any, is audible. Thanks again.
