Jball
Hi,
Equipment:
Amp: LFSUPER112 ( line out )
Di: Focusrite Scarlet 2i2 ( 3rd gen )
Daw: Ableton 12 lite
Cable: XLR3F to 1/4" TRS balanced
I bought the LFSUPER112 so I could use its line out to record some sessions. The music store recommended using an XLR3F to 1/4" TRS cable to connect it to my Focusrite interface. However, I'm experiencing some digital noise, and I'm not sure where it's coming from.
When using direct monitoring the noise is weaker and/or is not present, but when recording and listening in Ableton the noise is lifted, not hum, seems digital.
I've turned off the INST and AIR settings on the Focusrite and set the gain so that the loudest signal from my guitar peaks around -12 dB.
I'm trying to figure out if its my DAW, Interface, amp or cable.
Thanks in advance,
Jeremy
Equipment:
Thanks in advance,
Jeremy
