M
mykie_a
I know vinyl has a different signal output than line level...is it ok to run it's output straight to my MOTU ? I wanna tranfer to CD.
I just did the first vinyl transfer in about 4 years, and it was amazing to me how much noise was in those grooves!
That's a great comment Havoc...I have the HiFi News LP to try out:Havoc said:... And check the setup of your turntable.
Thanks GemSmith - I'm just getting started so I'm relying on tips like this until I get enough experience myself - Disc Doctor recommends this too which says a lot to me right now.GemSmith said:...the Audioquest record brush is absolutely indispensible as well...
You're welcome ! Just trying to spark a little debate so I can learn something...without spending too much on the wrong thingKevin DeSchwazi said:Some excellent posts here Kylen, thanks for the links.
) and if you don't already own specific software.Thanks Havoc ! You're right I better compare between my phono preamp and my mic preamp - I wanted to do flat transfers without analog RIAA EQ but I'll just do a couple of test runs after researching this some more.Havoc said:Regarding setup: if you have a test disc, then by all means use it. I don't have one, but I don't play much vinyl either.
But even a simple protractor and a balance like the shure sfg-2 can help you. Think it is best to do this before you use the test disc.
Regarding noise floor: if you try to measure the noise floor, do look at the frequency spectrum of it! You could have a mediocre noise floor, except for a single peak. Then getting rid of that peak can transform it into a very good one. Using a mic preamp might not be the best idea. The impedance they represent is far removed from what a cartridge is designed for.
