variable frequency power supplies
  • Thread starter Thread starter walters
The Kikusui PCR4000LA is an extremely high quality Programmable Variable frequency AC Power supply, Measurements include Full line voltage simulation (with option), Apparent Power, Power Factor, True Power, Vrms V,I rms A, I Peak A, Power W, Frequency Hz, Harmonic Current Measurement with Options RS232 Fitted as standard.
Specifications
Volt Range
1-300ACVrms / 1.4-425Vdc
Current Range
40A/20A
Power
4000VA
Frequency Range
DC, 1-999.9Hz
Output Phases
1 Phase
Cheers! :)
also if you're on a budget, check out the Behringer Ultra VariFreq 9608 Pro. it has a lot of the features of the Kikusui, but without the Full line voltage sim. but it does have switchable full line voltage simulation models, depending on what you're after. plus it comes with LED meters for Power Factor and Apparent Power, with a special 'blend' knob to control the mix of the Harmonic Current vs Power W. kinda gimmicky, but it gets the job done for cheap.
