Solved Why Isn't Power Getting To My 388's Mixer Section?
Mark7
Mark7
Everything else (recorder, monitor section and meters) are powered as per normal, but not the mixer. I've remedied the problem with the fuses (turns out there was a screw stuck between the monitor buss PCB and the one next to it (A? B? ???), which was causing a short; so they're not the problem this time. I also made sure the M buss board is seated correctly across all the boards and checked each trace for continuity. Doesn't seem to be any problem with that. Maybe I need to test for something other than just that signal/power is flowing from one end to the other, but I've no idea what to check for. Assuming it's not a misplaced connector.
