How should I set a compressor for acoustic guitar, acoustic bass, and vocals?
  • Thread starter Thread starter grimy paco
I guess there is no quick way to learn.
I will have to read read and read some more.I have read a couple of recording books but still very vague.
It will be try try again until I hear something I like.
Then try again.
Happy Recording Guys
:cool: :cool: :cool:
I have found the internet to be an extremely valuable resource for research.
Then try again.
You're absolutely about there being no quick way, and you're also right about books. They are kind of vague, but that's because every situation is different. In other words, don't waste your time looking for a book called "The Complete Guide to Recording, Equipment Settings, Mic Placement, and Setting Levels for Every Piece of Equipment Grimy Paco Has and the Way He Plays in the Room He Records In". :) :) :)
Take a non-recording example. I'm a Unix systems administrator and I've taken classes in various things to help me on the job. But taking the classes is only part of the training. I have to take the basic knowledge I get from the classes and then learn how to apply it to MY situation. In many cases the "normal" way isn't the best way for my situation, and it might even be the wrong way! The same is true for any job, and the same is true for recording.
You'll make a lot of mistakes, but the best part of mistakes is remembering what you did that failed. What really sucked in one situation could actually be a miracle cure for another.
yes I relize not all recording is common but as an example if I set my THRESHOLD to -50 dB it really would not matter what my other setting were because my distortion level will never be met to start COMPRESSION.
Assuming this is correct and please no remarks about assume we have all heard them before USAULLY at what level does a recording start to distort if figuring the TRIM on my recorder is set at moderate level.
If I increase the trim I should increase or decrease the THRESHOLD???
If I can comprehend this question it will start to make a little more sense.
THANKS
THANKS
Whew! This isn't going to be easy...
Grimy, since you were not kind enough to post where you are from (location: ______!) I'm going to assume that maybe we have a language barrier operating here. If not, forgive my assumption...
The reason why I say so, is because you are using terms in ways that don't quite make sense, so your overall questions make very little sense.
For example: "...if I set my THRESHOLD to -50 dB it really would not matter what my other setting were because my distortion level will never be met to start COMPRESSION."
First of all, a threshold setting of -50 would mean that all but the very softest part of your mix (like maybe the very end of the final fade) WOULD be getting compressed, because there is very little in the average mix that would register less than (-50)dB.
Secondly, compression has nothing to do with whether your signal is distorted or not, other than the fact that it can prevent distortion further down the chain by lowering both peaks and/or average levels. If the signal is distorted before it reaches the compressor because you have your preamp trim too high, the compressor cannot remove it, and it will only add to it if you misuse it.
So let's go back to square one: threshold is the level where the compressor starts to work. Anything below the theshold is uncompressed (although still subject to make-up gain). Anything above the threshold has a volume slope that is decreased by the amount determined by the ratio setting. Thus a 8 dB increase above the threshold point on the input signal will output at only 2dB above the threshold if you are using a 4:1 ratio. (8 divided by 4 = 2). The compressor has no way of knowing if the input signal was distorted or not - it will treat it the same either way.
The other important factor that must be considered in this equation is attack time. Attack time is like predelay on reverb units - it is the amount of time from the start of a signal before the compressor actually starts to work. The shortest attack time is often around 2ms. The longest might be around 100ms. If the attack time is too long, too much uncompressed material might get through to make it effective. If it is too short, everything gets compressed and the material might sound too squashed. We won't even get into release time at this point, which can be used to avoid (or create) "pumping" artifacts.
So balancing attack time, threshold , and ratio (as well as release time) is an interactive process. How they are set will determine what it is the compressor will do. A very short attack time (2ms) might work best with a high threshold (-5 to -10 dB) to clamp down hard on the loudest peaks. The more outrageous the peaks, the higher ratio will be needed at any given theshold.
But first you have to figure out why you are using the compressor and what you want from it:
Is it to act as a limiter to prevent digital distortion?
Is it to increase sustain on bass notes?
Is it to even out a performance by decreasing dynamic range? (Like making all the kick attacks the same volume.)
Is it to make a certain track stand out in the mix?
Is it to make a certain track lay back in the mix?
Is it to make an instrument sound "punchier"?
Is it to make an instrument sound smoother?
Is it to make a whole mix sound louder?
Is it to make a whole mix sound fatter?
These are all possible ways to use a compressor - and would each have completely different settings. Many others in above posts have already given you a lot of this same information, but you don't seem to quite have a grasp on it yet. This is not mean as an insult - compression is a bit tricky and can take a while to understand.
But as you can see, the complexity and variety of possible uses precludes a "one size fits all" answer to your questions.
Littledog yes there is a languge thing going on...
If you look at my profile you do see the word NEWBIE beside it so excuse me for the un educated questions.
If you do not understand them don't bother answering.
Right now everything does seem a little foreign to me but eventually I will start to understand.
My other reply then should have read if I set the Threshold to
+50 the compresser would not kick in.
I also was under the impression that it would help with distortion.
I now Know this would be limiting.
You see I am starting to catch on.
Thanks again
Thanks again
No need to get snippy. Many people here are not native english speakers, and without a location it is hard to know how much "misunderstanding" is caused by the language barrier or just by being a newbie. In your case, perhaps it might have been more clear en Français, but no insult was intended either way.
You said a lot of stuff about compression that either made no sense or was just plain wrong, and I was hoping i could help you. Since I can't quite figure out if you are telling me you would prefer that i should no longer respond to your questions: "If you do not understand them don't bother answering." or that you are thanking me for my extensive efforts to help you: "Thanks again" I guess I'll just play it safe and withdraw from the discussion and let you get your information from others. Most of them are probably more knowledgeable and articulate anyway, and I honestly don't know you well enough to get any pleasure out of annoying you... (like I would Blue Bear! :D )
You're welcome.
Littledog just a note .
Your feedback actually was a great help it was your harsh aproach that was discouraging.
THANKS
really and truly
:o
