antispatula
Active member
Ok, so no this is not another calibration question
, but I did discover the problem whilst adjusting the repro hi freq. level. I noticed when I played back the 10kHz tone off my MRL, after adjusting each level, they were all stable and at 0 VU, except for channel 8. The meter on 8 is all fluttery and unstable, but ONLY when reproducing the 100 kHz tone. On 1kHz, and 100 Hz it was perfectly fine, when I bypassed the repro head and just sent a 1 khz, and even a 10khz to the VU's using an Oscillator, it was fine. So it's ONLY messed up when I send a 10kHz tone through the repro head.......I can't get a stable reading, it's just flutters around 0 Vu, sometimes going above and below, as if it's spazing out.....
So anyone have any suggestions of what I should try doing? Should I disconnect the channels card from the terminals and just try disconnecting then recornnecting it back in? I don't know, I'm not too good with figuring out electronics stuff.....Any generall advice would be great though, thanks!
, but I did discover the problem whilst adjusting the repro hi freq. level. I noticed when I played back the 10kHz tone off my MRL, after adjusting each level, they were all stable and at 0 VU, except for channel 8. The meter on 8 is all fluttery and unstable, but ONLY when reproducing the 100 kHz tone. On 1kHz, and 100 Hz it was perfectly fine, when I bypassed the repro head and just sent a 1 khz, and even a 10khz to the VU's using an Oscillator, it was fine. So it's ONLY messed up when I send a 10kHz tone through the repro head.......I can't get a stable reading, it's just flutters around 0 Vu, sometimes going above and below, as if it's spazing out.....So anyone have any suggestions of what I should try doing? Should I disconnect the channels card from the terminals and just try disconnecting then recornnecting it back in? I don't know, I'm not too good with figuring out electronics stuff.....Any generall advice would be great though, thanks!
