nuemes
Be Here Now
So. I record dry and my recordings always lack the treble & presence that I hear in most indie/popular recordings in a typical rock setup (2 gtr, drums, bass, vox).
I hate adding EQ and do it as little as possible because at my equipment level (read: plug-ins), EQ can quickly add harsh tones.
So what would be the fix? I've got nearly dead rooms, which doesn't help add higher frequencies, but short of changing rooms how can treble/presence be added without EQ? I would assume the mic/placement would have the most affect, and then likely preamp but I'm not ready to look into more gear at this time.
For example, how would you go about getting more presence if you were recording a drum kit using MXL 603's (Digi002 pre's) as the overheads without adding EQ? Or do most folks add EQ at mixdown to bring higher frequencies up - in which case maybe this question is more appropriate in the mixing/mastering forum? Or have I neglected something(?)
I would recommend visiting the drum section and asking for some input on how to tune your kit to get a livelier sound out of it ... and what kind of heads to use and how tight they should be, etc.
